2019 Artic Cat Prowler Pro Soundbar & accessories
I just bought a 2019 Prowler Pro XT, i am installing street legal kit, roof, windshield, back windshield and 2” lift kit.
I am searching for recommendations on a sound bar that will fit to this unit well.
Open to other accessories i should look into. This Vehicle will be used for farm chores and family cruising around town and what not.
thanks
  • 4 weeks later...
    • By hetovi
      Hey everyone,
    • By jonny L
      Went for a nice trail ride for about 20 miles, came back, shut it off, and attempted to go for another ride. The electronic gear shifter will not go into park to start it up.  It reads neutral in the park position. Disconnected the battery and reconnected and it now read Park. But, when you put your foot on the brake to start it, it goes right back to neutral. Checked everything that I could think of and decided it has to be the 17 gear position sensor. Not certain this is the issue but I bought a used one on Ebay (could not locate a new one) and will try it. Any other possibilities?
    • By hetovi
      Hey everyone,
      I recently purchased a CFmoto ATV and I'm looking to add some accessories to enhance its performance and usability.
      I'm curious about what you all consider essential add-ons for a CFmoto.
      Specifically, I'm interested in accessories that improve comfort, storage, and overall ride experience.
      Are there any brands or products that you’ve found to work particularly well with CFmoto models?
      Any tips on where to get the best deals would also be appreciated. Looking forward to your suggestions and advice!
    • By amiracle40995
      I've never seen the temperature go high on this thing. the fan runs almost all the time even though the sensor is  reading at the very bottom of it's range. ive taken the cylinder head off.  (nothing definitive but maybe a little fuel on top of piston with oil in it.i don't think this has anything to do with my problem )head gasket is 3 layers deep and I noticed some grit that might have been in between layers but nothing to say the head gasket wasn't intact.  black carbon build up on piston. I've looked all over the head for cracks from over heating. I'm about to look again for hairline cracks that are extremely difficult to see. my buddy helping me said to order rings in case they are letting oil pass thru he also said get a new head gasket.. I'm looking at water in oil first and I'm not ordering rings. I haven't checked the oil cooler to see if it's defective yet.  I'm just hoping someone had a similar problem. my only problem so far has been having to change the spark plug every 100 miles with 93 octane run thru it.
    • By onealmck
