Rebuilding engine in our 2008 Trooper T2
By Alex
This is an interesting read. ADAS is main stream on cars these days. The technology looks to be headed towards UTVs and Off-Road Vehicles.
Potential Motors and CFMOTO USA have announced a new partnership to integrate advanced driver-assist systems (ADAS) into recreational off-road vehicles for the first time.
Sam Poirier, CEO and co-founder at Potential Motors, says the integration of its technology into CFMOTO’s vehicles will set new standards in the side-by-side segment. (Photo: Potential Motors Inc.) The partnership will first see Potential’s tech integrated into CFMOTO test vehicles. The companies will conduct extensive real-world testing at Potential’s purpose-built off-road proving ground in Fredericton, Canada, and CFMOTO facilities.
Source: https://powersportsbusiness.com/top-stories/2023/12/19/cfmoto-and-potential-motors-announce-industry-first-adas-technology-for-ohvs/
By hisun junk
I have a 2018 cub cadet challenger 750 with a broke chinese hisun motor and I know that I'm not alone! Almost all the places that were selling them in Colorado don't anymore due to the return for repairs on the clutches and broken timing chains! Don't have yours fixed because it will happen again! They just replace the broken parts with more junk chinese parts! I talked with a UTV mechanic that has replaced one person's clutch 4 times! I have people contacting cub cadet about these problems and also looking into complete motor replacement from hisun junk to a Japanese motor in which the chinese cloned their junk from.
By lmarkie
Any thoughts?
By mac66
By Ronald
Check engine light comes on after engine runs continuously for 5 minutes or so. I can shut down the engine and restart and check engine light goes out, then comes back on after running 5 minutes or so? What ya think?
