Rebuilding engine in our 2008 Trooper T2
By Jim Kessell
2005 American Landmaster
EH65 Subaru Robins
By TPlummer
By Reynolds Rocket
By lmarkie
Any thoughts?
By redneckred
Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X? I played with the gauges once and lucked up on this but can't remember what I did. Will the codes automatically display if there is a code or do you have to cycle through the display?
