Can Am doesn't make belts. They're just having the belt manufacturer put their name on it. Gates makes most of those belts. Either way, you can't go wrong with a name brand belt. If the price is the same, go with the CanAm. You can't go wrong with OEM either, and the fit is almost guaranteed.
    • By Cory J
    • By hetovi
      Hey everyone,
    • By kadams428
      Recently my four wheeler has had an issue of being set in gear and it begins riding on its own (up to 3-4MPH). It also is having difficulty shifting into different gears after riding in one gear (i.e. going from reverse to high gear). It will shift perfectly fine when shut off, but consistently has both issues stated above.
      Previous research has shown me that it could be an issue with belt tension/deflection, however I have been unable to figure out how to do that with these machines. I've seen some clutches have a jam nut and all that is needed is a wrench and an Allen key to make adjustments, but I haven't seen/found that on the 600 clutches. Has anyone done this in the past or have knowledge of how to accomplish this?
    • By Alex
    • By tim hughes
      does any one else have a slipping belt on the hisun ...i put new wet clutch one way bearing new belt, cleaned primary and secondary and still get slight slippage
