2018 Polaris RZR
By Bryan83c
Need input on compatible clutch sets I can upgrade joyner 1100cc 2018 sand viper with. Something autozone might carry and what cars are these chery motors most compatibility with
By Chile
I have a 2018 Massimo 700 MSU with the Delphi MT05 ECU.
I have seen an alternative ECU reset procedure that involves running the engine at WOT for 5 seconds in neutral and then shutting down while throttle still at WOT. The articles include comments that the rev limiter will prevent engine overspeed ad attendant damage.
1. Is this actually a recommended procedure for restting the ECU on a 700 MSU?
2. What is the rev limited maximum RPM for the 700 MSU?
I initiated this procedure but when the RPM exceeded 6000 I immediately terminated the process. It simply seemed excessive to me to continue.
Any and all responses are greatly appreciated.
Chile
By Stan Morton
My 2018 XG-850-SL starter died yesterday. The old part number from Kubota is E7153-11732 which has been superceed by part # EG881-63010. I am looking for an aftermarket starter because the Kubota retail price for the starter starts at $550 and upwards toward $850. If anyone has gone down this road before and has found an aftermarket starter ~ please share with me. We own a ranch and this thing is used every single day and is sorely missed when it is down for maintenance. Kind Regards, ~ Stan
By Michael Wood
I have a 2018 Massimo Buck 400 with 278 miles.
Having issues with my brakes. Took the buggy hunting and when I let my foot off the gas pedal it pulls without pressing on the brake. I looked and the pads on all 4 wheels are all toast. The E-Brake hasn’t been on since I have had it. I am guessing it may be a master cylinder issue because all 4 pads are gone. They all seem to have worn evenly that’s why I think the master cylinder. Just got the machine used from a older couple and they said it sat for some time in there pole barn. Possibly the brake lines? Calipers? I took one brake apart and when I depressed the caliper it didn’t stay. Any help is muck appreciated.
By joeam
I have a 2018 TW450E that runs in my yard and slow good just will not go down the road seems to be running out of fuel where should i start? I have replaced both fuel and air filter drained gas and tried a small auxiliary tank same issue i have ordered a new vacuum fuel pump to try next anyone in Texas that works on these?
