Has any ever removed the entire steering components for a HBR? 2010-2012 preferable. Lost all steering ability this weekend, and starting tearing down the tie rod ends, steering gear box (rack and pinion assembly), and the steering shaft. Having a hard time figuring out how to get it out, and removing the steering shaft near the gear box.
    • By Bjabbarw
      My 2021 Odes Dominator 800 bogs down at 25mph and won’t go over that speed. I have changed the fuel pump and it still does the same, it runs and idles fine, it has great reverse speed, but it won’t accelerate past 25mph. Any Ideas?
    • By Ductking1
    • By Justine
    • By A P
    • By mark walkom
