Hi I just bought a 2020 tracker 800sx crew and looking for a lift kit. It's an identical twin of the 2019 Textron prowler pro crew. It has decent ground clearance at around 11 inches but with the long wheel base of the crew it tends to drag it's belly a good bit. I'll probably end up making one but just seeing if anyone has seen anything yet. Thanks
  • 4 years later...
    • By NC4wd
      Has anyone found a lift kit that fits an Axis 500? Mine is a 2021.
      I added lights to the Coleman Outfitter 550 last fall.   I bought lights on line from Nilight, a 300 W  12" light bar mounted forward and 2 square 4" floods for the rear.  Those are mounted on the roof corners facing rear and downward just beyond the tailgate.  Nilights seem to be of high quality, as I've had them on my garden tractor for 5 years and still flood the way ahead with great light.
      Both the front and rear lights provide amazing illumination making the OEM headlamps look like parking lights.  Made a connector for the front bar that plugs into existing headlamp switch so it is just part of that circuit controlled by the headlamp switch.   Rear work lamps were wired in using a rocker switch installed in the dash.  Backed up to the garden with the work lights and was able to harvest some tomatoes well past sunset.
      What have you used if anything for auxiliary lighting on your UTV?
    • By diamondjfarm
      Thanks.
    • By Dana Stewart
      Is there A lift kit for a Hisun Sector 750 " +/- ? LINKS?
