Headed to the dealership to pick up the part. HOPEFULLY i'll be driving by this evening. Or my other parking brake cable will be seized up by the time i get this one back  on.. lol 😆 ;)
  • 2 months later...
Just picked up this exact same Mule for a good deal and then I found your thread here.  Good stuff, doing this right now.  I may need to pick your brain at some point.
So the OEM drum brake cylinder is stupid expensive, but I just test fitted a Dorman made for Suzuki ATVs, and it's almost a perfect fit.  The 2 mounting bolt holes are just a little off, but nothing that can't be handled by oblonging the holes in the drum back plate.  And for <$11, it's worth it.  Dorman W37850 Drum Brake Wheel Cylinder https://www.amazon.com/dp/B001PYV1I0/ref=cm_sw_r_cp_apa_i_TL5UDbWR61Q68
Yep, and, the OEM mounting bolts and the brake line flange nut are the right size/thread too.  So I thought it was a pretty good find.  I might have to try one of these $15 Amazon carburetors next just for fun.
Yep, I'm about to take off my carb, as you know it's been idling rough. Then dying.
they say these Mikuni carburetors are real finicky.
I've had good luck with Chinesium carbs for Briggs engines. Though I hate to buy them OEM is so dang expensive.
Well it looks like this carb for a Kawasaki FE290 engine is really common and used in a lot of John Deer Gators, Club Car golf carts, and quite a few lawn mowers.  There are a lot of versions with it and seem to revolve around exterior dimensions for the throttle stack height and choke orientation.  But the bolt holes and throat dimensions seem to be the same and I bet they'd cross over from model to model fairly easy.
  • 3 years later...
I am replacing the parking brake cables on my KAF300B2 500 mule. There were missing when I bought it. My question is, what holds the cable into the back plate of the brake assembly? There are grooves in the cable end but none of the parts diagrams indicate a clip or anything to hold the thing in place. I was able to stick them in the holes and use tie wraps to secure the cables in place but that doesn't seem like a good long term solution to me.
       up.
    • By Gorj
      I have had my E1 since late last summer and I have always noticed that the parking brake was weak or non existent. About a month or so after I purchased it I mentioned to the dealer that the parking brake did not function well. What I was expecting from the dealer, ' well bring it in and we will correct the issue.' What I got was the typical dealer response, "it may just need to be adjusted." No shit!  Well I finally decided to adjust it. A very simple process need only two 10mm wrenches.  Open the bed, remove the pin holding the bed  to the strut and move the bad out of the way. Right in front of the electric motor is a brake disk.  That is the parking brake. It has a small set of brake pads that are actuated by a lever attached to parking brake cable.  There are two 10 mm nuts on the shaft to moves the pads. Release the inner nut and hold it in place while screwing in the outer nut - that is really a bolt. After screwing it in about one turn, tighten the other nut.  Check the parking brake. If it is holding when activated, then you are good, but if not, then you may have to turn the bolt another turn. Do not turn to far or you will lock it up.
    • By Michigan sport.
      I'm sure many of you are aware of Michigan's emergency brake requirement.  I'm wondering if anyone has a good solution.
      Beyond paying the few fab places $$$$.. I'm curious is there another rear caliper with e brake style that would interchange with slight mods to  the Maverick sport rear mounting bracket?
