Coleman Outfitter 550 E Brake adjustment
By Tim n Deb
Riding out today it acted like it ran out of gas, stalled and died and would not start. Towed back to house, New plug added this past month, plenty of oil, getting plenty of gas, battery cranks good. Trys to kick in and starts but doesnt. Two days prior while sitting at a idle it died. Added gas and it started did my ranch chores with it. But just now it stalled out cranks but will not start. Tried to find if fault codes came up on the clock like manual says but not sure I am doing that right. Any and all help apprecated. Thank you
Has anyone installed the power dump on a Kioti K9? If so, does it eliminate the safety lock? Does it work well?
Thanks for your input
By monkthumper
By amiracle40995
By BigWave
Bigwave
