 Nothing I'm just lucky enough to have one of the years that came with the cast iron manifold..lol  And I've been looking to upgrade to a tube header for years. I'm hoping that someone knows where to get one or has one laying around!
We can make you one but in reality it wont give you any more performance
Try Joyner USA they might have one
Chris
West Coast Fabrication
I have a custom intake with a larger throttle body, it's port matched - polished and supercharged.. Thought it would help me a bit over my modified exhaust with the cast one..  How much would you charge for one?
    • By CYJSP2009
      Dear Joyner owners
      3. Cables,
      4. Brake parts
      5. Engine parts
      6. Other parts.
      Have a good weekend
      Casey /  Leaf Asia
      2023-11-17
    • By Reynolds Rocket
    • By lmarkie
      Any thoughts?
    • By redneckred
      Can anyone tell me how to get the engine codes to display on a 2012 Bennche Bighorn 700X?  I played with the gauges once and lucked up on this but can't remember what I did.  Will the codes automatically display if there is a code or do you have to cycle through the display?
    • By joynersfuntillitbreaks
