I like it and definitely think it was the right choice for me. This vehicle is a true workhorse. It has plenty of power. I just plowed 13" of snow with it and was very surprised how much power and traction it maintained while pushing snow. Locking the differential allows you to plow very slowly without fear of losing momentum. Honestly, my only complaint is the loudness of the engine and exhaust. It's a loud diesel. Especially while driving full throttle. The reason I got the Kioti instead of the Kubota is that the Kubota only had a top speed of 25mph. The Kioti will go 35mph. Might not seem like much but when driving on roads, it makes a difference.
That’s great CSM.  You must have the K9?  What type of plow did you get, was it hired to install?  I have 2200PS, and after the first year of warranty problems, I like mine too.  Mine tops out at about 24-25 mph, but I don’t run it that fast.  It’s too loud.  I don’t have a plow, but I’m thinking of getting one.  I did install the skid plates, CV guards, roof, windshield and light horn set.  Sadly mine has so many problems from the get go, the dealer had it 7 of the first 12 months.
  • Sad 1
I guess you got a bad build. The only issue I've had is a coolant leak due to a loose hose clamp. No other issues so far. The plow is a sno-way 6' straight blade. Power up/down and side to side. Really nice feature that the sno-way offers that I haven't seen any of the others offer is a power down mode. Most plows are floating or gravity down but this one has a feature that pushes about 300lbs of pressure down to scrape to the asphalt the first pass.
On 1/19/2025 at 9:42 AM, CSM_Retired said:
Any Kioti owners out there know of any websites or companies that offer aftermarket performance parts for the 24hp diesel?
Resending this for members that may have insight and haven't seen my first request.
Thanks again for any input
Sounds like my Massimo...it was in the shop so much , it was like they owned it and I was just borrowing for a weekend..But Massimo never paid the warranty claims..not one.
9 hours ago, Ridge Runner said:
CSM
I have not found much, other than mirrors on Amazon, as aftermarket for my Kioti, 2200PS
Funny you mention that. I purchased the factory mirrors from Kioti. Well while plowing close to Arborvitaes the passenger mirror broke off. Turns out the only thing holding it on was a bolt just countersunk in the plastic mold. Terrible design! So I replaced the mirror part with Amazon purchased cheap UTV mirrors. They look and work better then the much more expensive factory mirrors. If interested I can upload a pic.
I own the Kioti K-9 2440. I purchased it back during the pandemic when Deere and Kubota could not be found in inventory. I previously owned a 2012 John Deere 855 D and ran it for 10 plus years on a commercial poultry operation 7 days per week. It had over 5500 hours on it when I sold it to an employee and purchased the Kioti. The K-9 has not been a reliable unit. With only 750 hours logged, it's spent over 3 months at the dealership for miscellaneous repairs, mostly clutch and drive-line issues. The diesel engine has been great. It's now down again. The primary CVT clutch separated. I carried it back to the dealership and they quoted me a repair estimate of $2,290 to replace the primary and the belt which is only about 6 months old. Declined his offer and retrieved the unit from the dealership. Today, I finally had the time to pop the primary clutch off and discovered the back side of the pulley completely separated from the clutch assembly. I'm now looking a better clutch option. Obviously, the OEM won't cut the mustard. I've contacted Mother Clutches. Hopefully, they have an aftermarket that will be a little more durable.
    • By Edelbrock
      Thoughts?
    • By Unhappy Kioti K9 Owner
      Greetings All,
