Welcome aboard..overheating is a big problem with these things. I assume it's a Hisun engine?  Loosen a hose or the temp switch on the radiator. Be sure to get all the air out when you refill it..
Exactly as Joe said. You have to loose a hose to drain, no petcock.
When you add coolant. Be sure to raise the front end. The higher the better. Then on, my axis 500 and others, there's a bleed screw/bolt on the gooseneck on the head. Where the coolant hose connects to the head. Be sure to bleed/burp all the air out.
I recommend bleeding there multiple times. Over a course of multiple heating up cycles.
If your son did get it hot. Once you have all the air out. Check and make sure there is no coolant in the oil. Make sure there is no bubbles rising in the overflow coolant catch jug with radiator cap on once the engine is up to operating temp.
On my axis 500, the temp sensor is on the gooseneck at the head. That sensor turns on the temp idiot light on dash.
There is also a temp sensor on the radiator. That one tells the electric fan to kick on and off.
Best of luck and welcome to the forum from KY.
above steps are right on BUT to make the job easier AND QUICKER...beat the book------------bleed the air from the overflow line (hose) to the puke jug.
1.  Fill the puke jug above the cold line by about an inch with straight antifreeze......no mix.....with the hose connected between the puke jug and radiator neck
2.  fill the radiator fill neck one last time to the top.  Will try to drain back into the puke jug........normal
3.  seal the tank lid along with an added air hose with a shop towel and blow air (lung power is just fine---you don't want a fountain for the neighborhood cats to lap up---- into the puke jug........forces the coolant up into the radiator filler neck.
4.  When the bubbles stop and the concentrated antifreeze swirls into the filler neck.....maintain pressure and then install the radiator cap.  no drain down of antifreeze.
5.  release air pressure and remove the sealing shop rag and hose tubing....... install the puke tank lid.  This saves the time wasted on having to heat cycle multiple times to purge the line to the puke jug.   chow.
    • By Tejun
    • By Bryan g
    • By dman66
