Hello All...
Welcome to the site.
Consider testing and diagnosis before throwing parts at it.  Doing that only compounds  the problem and often masks what is actually wrong with it.  Rember the basics of ICEs.  Spark, Compression and Fuel.
Test for spark and compression. Then try firing it up with a dribble of gas into the cylinder to see if it will run for a second or two.   If it does, you've narrowed the problem down to fuel delivery.
I've read that some of these earlier models particularly  Hisuns were shipped without in line fuel filters.   Their fuel injectors are sensitive to poor or dirty fuel so they quit or won't let it run much at if at all.
Good luck Doctor, hope you diagnose the disease and that whatever it is,  its an easy and cheap cure.
Thanks.  Someone has already hung several new parts on it, to no avail.  That's how I got it.  I can't get it to the shop for another couple of days due to the snow storm, but hopefully by the end of the week.
Welcome, to the board. In in Eastern, KY also. Not any local authorized repair shop around here that I can find. Haven't tried any other place.
Since it been down for a while. Charge the battery. Then check for spark. Check for any loose wires and connections.
I changed the oem seats in my Axis 500, replaced with seats from a RZR from ebay. I made the seat base and they fit pretty good. I gave 1 of the seats to a guy up the road for spreading some dirt in the driveway. Gave one to my brother to replace a seat on his mower.
Good luck, let us know how it goes.
Thanks.  I need a passenger side seat also.  Been watching Marketplace but nothing yet.  I guess I'll have to bite the bullet and buy a new one.  Won't do that until I get it running.
Hello All...  (2015 MSU 500)
Well, I finally got a chance to start the diagnostic on the machine.  I have found: 1) has spark, 2) has fuel, fuel pump working (and injector is spraying), 3) has compression.  Cranks (at a good speed), but will not start.  Sounds like it wants to start, fires every once in a while, and the use of starting fluid makes no change.
Not sure if the valve timing is correct.  Does anyone know (or know of a good place to find) how the timing marks should be aligned for TDC ?  There are 2-dimples on the camshaft (opposite of one another), and currently they appear to be in line pointing to the crank at I think what is TDC (i.e. in line with the piston, rod, and crank).  I can't find an inspection window to see any crank timing marks.
Also, I have what I believe to be some fault indicators displaying on the dash info display.  They are as follows:  201, blinks 4 times, 202, blinks 4 times, 352, blinks 5 times, 336, blinks 5 times, and 37, blinks 5 times.  Anyone know where I can find what they may be indicating ?  The ECM looks brand new, and the fuse/relay box was replaced by me (previous owner destroyed it trying to get it open).
The unit has only 775 miles on it, and 127 hours.  It's in good shape, with what I believe all original tires and equipment (although it's missing a passenger seat).
 Any thoughts would be appreciated.
Thanks...
Larry
Best thing is to reset the ECU.
With the key in off position. Turn key on then off 5 times within 30 seconds. Make sure the fuel pump kicks on each time. After the 5th on/off cycle. Leave off 1 minute then try to start the machine. That should clear the error codes and reset the ECU .
Proper procedure to start is turn key to on. Then once the fuel pump shuts off. The proceed to the turn the key to the start position to engage starter.
On this site there is a download section section where shop manuals can be searched for.
If the ECU looks new it may have been replaced. It's also possible that it was a bad replacement. I read somewhere or watched a video stating that bad ECU for these machines were being sold on fleebay. Hope that is not the case.
All those codes deal with spark in one way or another.
To search for manuals click on the 3 bars in top right corner. That will take you to a webpage to search for a repair manual. You'll probably have to remove the fuel tank and the air blower to get access to the tdc inspection port. Directions are in the manual
Good luck
    • By Edelbrock
      Thoughts?
    • By UTVLover253
      What you love about it
      What frustrates you
      – Adam
    • By Sando
    • By Unhappy Kioti K9 Owner
