Hello All...
Welcome to the site.
Consider testing and diagnosis before throwing parts at it.  Doing that only compounds  the problem and often masks what is actually wrong with it.  Rember the basics of ICEs.  Spark, Compression and Fuel.
Test for spark and compression. Then try firing it up with a dribble of gas into the cylinder to see if it will run for a second or two.   If it does, you've narrowed the problem down to fuel delivery.
I've read that some of these earlier models particularly  Hisuns were shipped without in line fuel filters.   Their fuel injectors are sensitive to poor or dirty fuel so they quit or won't let it run much at if at all.
Good luck Doctor, hope you diagnose the disease and that whatever it is,  its an easy and cheap cure.
Thanks.  Someone has already hung several new parts on it, to no avail.  That's how I got it.  I can't get it to the shop for another couple of days due to the snow storm, but hopefully by the end of the week.
    • By Chucky 1
    • By TexAcoon
      I'm looking to purchase a 2015 Massimo 550 that might have an issue with it's throttle position sensor.
      From the fella selling this UTV, he claims its to set the idle on fuel injection because the engine will not stay idle or when it starts sometimes it idles too high.
      My Question if anyone had any issues with their Massimo 550 and if it was actually the TPS or something else that would allow the machine to idle correctly.
    • By Gerals
