Thanks in advance.
Not sure if this would be an option for your 550: I'm using a 72" KFI plow on my Hisun Sector 750 - works well. Driveway is 350'+ x 12'. One pass down the middle and then one on either side. (photo is UTV with plow at the dealer's - was delivered that way). Note - need to manually adjust plow angle.
  • Like 3
That's a great photo, thanks for posting it.   KFI seems to be one of the few suppliers of plows fitting the Hisun line of UTVs.  Your 750 looks to utilize the same frame/body as my 550.
Now I just have to get over the cost thing.
Got almost the same machine and set up. Bought mine in Peterborough ON.. but the engine and tranny I am not too happy with..
It does the job to plow  but I can't go over 15mph without hearing the engine roar..  tranny is terrible especially hitting LOW
43 minutes ago, Alien10 said:
Welcome to the site H Loc.
Could you elaborate on the engine and tranny issues a little?  Slipping, grinding etc???
when I fire it up the check engine light comes on and idling feels like engines gonna die then check engine light disappears and idles fine.. its extremely loud which apparently is normal
then I press the gas it revs really loud to about 3000rpms and that's when i don't wanna go quicker then 15mph   i really wanted to go faster
the tranny sometimes doesn't engage.. especially when I want to go to LOW..  usually I have to make sure it engages to HIGH first then switch to low..  sometimes the gear is just hard to move..  maybe bc wheels are turned too much   idk..
but this week I will take some videos  not sure if I can upload them
I have  a 550 and the gear shifter is a stiff, often difficult thing to use.  There is a trick to getting it into low without it popping out of gear when you give it gas.
My "LOW" is all the up on the shift knob.  I saw a Hisun dealer video that said to keep upward pressure on the shifter with your hand as you slowly give it gas to move forward.  There will be an almost imperceptible "click" when it starts to move.   Mine does this 7 or 8 times out of 10 and as long as it does that last tiny click, it won't pop out of gear. I operate on some very steep inclines so I have to be sure the low range IS engaged.
I think the check engine lamp is also the oil pressure monitor but I could be wrong.   I always wait the few seconds until the check engine lamp goes out to shift into gear and move.
My 550 does exactly the same on start up.  I found that if you turn the key on, and wait a couple of seconds for the fuel pump to get up to pressure and stop before cranking to start, it usually will not try to die out when it does start, or lessens that.    Sort of guessing that the injector may be slightly starved for fuel while the pump gets up to pressure.  Once there, no problem.
Lastly, these like premium gas.  They will run on 87 octane but prefer higher. Also look to be sure your machine has an in line fuel filter.  Some were shipped without them causing early injector failure.  Those don't like any dirt at all.
I appreciate this insight.. Helps a lot.. Now I feel I am not the only one experiencing these symptoms
How fast have you pushed your machine  over 25mph yet?  I don't dare has the engine revvs so loud  feels like I might blow the engine
I seldom have a reason to go over 20 to 25 mph but I think it is capable if I wanted to.  I think the 550 tops out around 40 to 45 in high, but I haven't really tried that. Most of my property is on hillsides so I only use low range, it has plenty of speed for the 1/8 mile trip down our dirt road to my barn.  It does get a little loud even at 20-25 mph, but not alarmingly so. Its just the engine revs. It should be smooth.  Can you tell if this is exhaust noise or is it noise from something internal to the engine or trans. Maybe remove the dump bed and have a buddy listen out the back window to see if he can spot where that alarming noise is coming from.  Also note at which RPMs the noise increases more that you'd expect for the given RPMs.
Do you have any other issues with engine, like hard starting, or backfiring?  Or how about transmission or belt slippage?   Also is it the same loudness when in high range?
Be sure engine and trans mounts are all secure. Check to be sure nothing on the body is touching the engine and maybe magnifying the noise at higher RPMs.
    • By weasel
    • By Roadstar515
      Regards, Rick
    • By fikey
      I am considering a Hisun 550 for tooling around the farm> I have a Kawasaki Teryx 4 and deeply disappointed at the difficulty of getting to the engine and belt for repairs. I would like some feedback on the Hisun's reliability and ease of access to work on. Thanks.
    • By FDWT9956
