I have a 2016 Cub Cadet Challenger 700 that has ~40-50 miles on it,,  and similar hours.     It had the Brake recall completed in summer of 2017 and in summer of 2018 after sitting for a month of non use the brake pedal pressure became soft and would not stop quickly as normal.   I took it to the dealer and they "fixed" it and it worked fine for the past year but again this past weekend I took it out after not using it for 5 weeks and the pedal is soft again and takes forever to stop.  I plan to call me dealer again to see if they will fix again but I am wondering if anyone else has seen this and if anyone knows what it could be.      No visible leaks and machine is not worked hard.  I use it to drive around my property.
air is getting in the brake system somehow.
I'd have the dealer check that all fittings or joints are screwed in tight at the master cylinder , wheel cylinders and any other joints.
    • By CapnWalleye
    • By CapnWalleye
    • By Joe Breaux
    • By rdborra
    • By Jim Kessell
      Hi All
      Jim
