I would check for fuel contamination, water or too much ethanol in bottom of tank. I have a Hisun tech coming Monday to check my 2022 sector for that condition, mine loses power going up my long-inclined driveway.
nods
    • By Pick a name
    • By MikeM1
      2025 axis xs 750 no place to mount license plate and no light for it has anyone fixed this issue
    • By Xov
    • By Gorj
