                              Thank You,
                            D Maynard
If you already replaced the stator and the pickup coil make sure that all your connection are connected. Crank it over by the starter motor and hook up the wires  from the stator to your test meter to determine if power is coming out of the stator, then check the coil to determine if your are getting power.
I will try what you suggested tomorrow,  thank you for responding and I will update results as soon as I have them.
  • 4 weeks later...
    • By CapnWalleye
    • By CapnWalleye
    • By Bobbers
