Past experience for a random (as in your heat soak cycle-----engine hot and will come back to life again with some cooling) is the pick up coil.  Next is the ignition coil.
Use a spark gap tester and watch the spark quality and/or hit and miss or dead.  The really OLD timing lights (60's) used just a dim neon tube.  A weak spark would result in a really dim or non flash.  Also, Snap-On sold a handheld spark voltage tester with flashing LED indicators and a thumb wheel voltage trip point selector.  Lab scopes give a visual check if you know a friend who has one with the spark pick up clamp.
STORY:  I have had some pick up coils that would take forever to fail and then heal BEFORE you could pull the connector and connect an ohm meter to check for an open coil instead of the spec'd resistance.  That one was solved by using a DPDT switch to check the resistance right as it died......could watch it "heal" again in less than 5 seconds.  It had been thru a bunch of shops before me.
    • By judy140
      I am looking for a service manual for Bighorn Explorer 400
    • By strike250
      Matt
      Thanks in advance.
    • By Tejun
