Travis the model # from the SxS is
model # 431 ( 37AR430D100 )
serial # 1H153B00010
The “ B “ in serial# maybe a 8
731-04333 / 931-04333 is C.C. part number for the
Diff. Lock Actuator  (vacuum operated)
This is what I need most .every place that shows them say not available.
The roll cage , roof and rear fenders I can live without but just would like to find them as well.
Thank Randy
    • By Marie
    • By Xov
