Posted (edited)
Hello hisun owners! I love my utv.
but as well other utv types mine needs some help from time to time.
the voltage regulator fried  a pin hole on the plug it goes into. There are 6 pins on voltage regular so I am trying to find the plug that it connects to. No luck online.  Called Coleman company and waiting for help to replace plug.
Anyone have a clue where I can buy a new plug?  I use my utv for several projects and need this fixed fast!
Thank you for any helpful replies.
Edited by Utv51
Typos
Welcome to the forum!
 I wasn't sure which series HiSun you had, but  you can find them on the left side of this  Parts page. you might can find it here. https://alpha-sports.com/hisun_parts.htm?q=hisun-parts
 One thing i would think about before putting a new plug on, is what caused it to burn it out. Could be just a cheap part, or just time won the battle, or another electrical issue.
a regular 6 pin would more than likely work, but  im not sure if the wires are supposed to go a certain way or not.
    • By Ductking1
    • By hisun junk
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By SouthernGypsy
    • By Justine
