I have a pretty bad vibration on accelloration at speeds, not from a stand still. U-joints & center support are fine, no slippage in the clutch, engine is fine, runs normal. Wheels, brakes, bearings all good, CV joints ok and really nothing obvious causing this vibration.
I am wondering about the Drive Convertor. Does anyone know what a bad convertor can produce as far as problems go. I have not diss assembled or inspected it yet. I have replaced the clutch a few times  over the 26 years.
Welcome  to the forum!
I'm not sure what could be causing it, but it could very well be the interior of the centrifugal is wore out. It is belt driven, correct?
If you could post a video that would be very helpful.
Hey Travis. It is belt driven. I am going to disassemble the clutch area this weekend. Maybe I will find something in there. If I did a video, what were you thinking it would be of? The vibration while its moving?
Expand
This just got me thinking.
 My 550 has the same drive set up as yours.
 Start the Mule, and put it in Neutral, and rev the engine as you would speeding  if you while driving, if there is no vibration, then more than likley it ISN'T the clutch. be cause it operates the same as when you're in gear.
 Did i make my point clear? i'm bad at transferring thoughts into  typed words.
Hi Travis,
Pretty sure I did that already. Good thought for me to double check that. This is what made me ask about the converter. I will check this tomorrow. Sure do appreciate the  support here. I will post back this weekend.
I'd try jacking it up, and put it on stands. Then put it in gear, and try to replicate the vibration. You might be able to narrow it down if its immobile, with only the drive train in motion.
    • By CapnWalleye
    • By ToughLuck
    • By CapnWalleye
    • By aefron88
    • By SSgt1994
      Myron
