As was already said, make sure the fan is working. You can easily hear it. Get a continuity tester and test the fan switch. Jumper the fan motor and make sure it works.
Fan is working, so I don't think that is the problem. I have driven the mule around a good bit since I had the problem and it has not overheated again. I am stumped as to what to do. Do I change the thermostat anyway in hopes it was a random event that will happen again. What else could it be? Thank you all for your opinions.
    • By Unhappy Kioti K9 Owner
    • By Paul L
    • By rsar
    • By rdborra
