guys- machine ran fine - Pushed button to put in 4 wheel drive and the machine died- I have power at battery and to the fuses but everything is dead-- PLEASE let em know of any ideas- I really do not know what else to look for- thanks
Come on guys someone must have an idea-= Checked again and I have no power coming to wiring harness ignition switch- anyone know where the safety switches are located= really not sure where to look anymore please help--
Sounds like a dead short in that swith, or somewhere in that circuit. Probably blew a main fuse. You said you've got power TO the fuses. What about after? Limbs, and rocks, and other road debris is often the culprit here. Check the switch with a continuity tester. Then look around underneath where the wires go into the front drive. Or the transaxle or whatever it has.
It's possible that it's something else, but since it happened when you hit the button. That's where I'd start looking. If it's a push button activated 4wd. There's a relay that'll drive the actuator. Both those are prime suspects.
    • By se3388
      Steve.............
    • By JOSEPH LAMAR
    • By A P
    • By Will Sutton
