Shifting issues
By Joseph Sills
By Bryan g
We see a lot of the UT400 with shift problems, not going into gear, popping out of gear, grinding etc. There is a bulletin Im sure everyone has saw about adjusting shift cable. That dont always fix it. I went round n round with coleman on couple units. We are a Coleman warranty repair center"AFS Small Engine Repair " I told them shift lever does not have enough travel . No amount of cable adjustment will increase travel . I extended lever with piece on flat iron by 3/4 of inch . This gave shifter enough travel to properly engage into gear completely . Last couple units to come in for this Coleman sent me a modified shift lever, with longer travel . Problem solved! Also , heads up if you get any new unit ,,,go over and check it out, grease all zerks, check air filter for being in backwards, check wiring harnesses for rubbing on rotating parts, brake hose routing , make sure not touching exhaust . These are just few of the more common failures I see .
By downseast
Hi everyone
By downseast
Hi everyone
When I go to start it clicks as if there is a hydraulic lock and wont turn but after two or three attempts it then does turn over and start but I need to give it a bit of throttle to start – is this normal ?
I haven’t changed the Lambda
sensor yet, anyone know how much difference this might make ( I have a new Bosch universal to fit )
I believe the T Boss was worked on by the previous owner
