2013 Bennche Bighorn 700 EFI
40 minutes ago, Charles Green said:
Did you check for 12v at starter solenoid with key in start position?
Did you you check fuses?
As he's saying, first thing is makes sure there is 12v on positive probe with negative probe on the metal chassis or even the motor itself.
I had 12V on the one post, but nothing happened when I turned the key to start it.  It ended up being a loose connection going into the relay/fuse box.  Far right connection doesn't seat the whole way.  I have it ziptied in place for now, but would like a better solution.  With the wiring fixed, I did a valve adjustment and it fired right up, but seems to be lacking power on hills.  I just ran it around my yard real quick and definitely feels like it's lacking power on anything other than flat ground.  I guess I'll have to inspect the clutch next.
    • By Gorj
    • By Marie
    • By Marie
