Tracker 800sx crew 2023
By Pick a name
The Axis 500 will not shift into low or reverse. I have high when it should be in low and all the other places it is reverse. The gears in the shift cover are fine and I shifted it when the cover was off and yet no change (so it can't be the shifting mechanism gears). I t has been difficult to get it into low for awhile. But now it is either high or reverse, no neutral either.
By SSgt1994
Myron
By Tejun
By Flanman55
2007 Hisun HS700 will not crank. Replace the ignition switch. Same thing. Replaced solenoid by the battery same thing. Can jump it and it starts good across the solenoid posts. Ran a jumper wire from switch to solenoid. Nothing
By Croppy38
I own a 2017 Challenger 750 and had the key way snap at the flywheel. It was removed and cleaned up and then the flywheel was put back on with a new keyway. It snapped a second time so the flywheel and keyway both were replaced. They both seem to fit nice and tight. Put it all back together and it snapped again. I have no idea why it is doing this.
