What year is my RTV
By Paul L
By quint725
Hello! I picked up a Facebook especial and was curious if I could get some help identifying what exactly it is. It was labeled as a Mossimo 500, but I can't confirm that. The closest I've seen is a Hisun Supermach 500. I bought it as a project but without knowing exactly what it is and the year it's hard to buy parts for it.
What I do know is that it has the Hisun 500cc carbureted engine, and I can share the VIN if that helps.
Here are some photos
Thanks in advance
