  • Alex changed the title to 2510 Kawasaki mule Diesel
if the input shaft into the transmission is turning, and the wheels aren't there is definitely a internal issue.  I'm not 100% how the shift linkage is hooked up on the 2510 but lift the bed and try manually putting it in forward or reverse and make sure it has full range of motion to go in gear.
    • By Xov
    • By rsar
    • By D MAYNARD
    • By Will D
