On 3/11/2025 at 6:31 PM, Gorj said:
I would suggest you look more closely at the continuous discharge rate of those batteries.  810 is almost certainly just the cold cranking amps.  I suspect your performance in a UTV application is going to be seriously degraded - like at best a continuous rate of under 100A and potentially even less.  Plus, even a deep cycle battery can only go down to 20% and there will be a voltage drop.
Also, the plates used in deep cycle batteries are often not made of the same material and thickness as those in batteries rated as traction batteries, so in the UTV application the marine batteries are going to fail sooner than even the Discover batteries.
I replaced the defective battery and everything is back to normal. Installed digital volt meter shows 51.9 volts when fully charged. Am again able to climb the steep hills on my property. I did not replace the expensive Discovery battery. I used a deep cycle marine 6 volt battery
    • By UTVLover253
      What you love about it
      What frustrates you
      – Adam
    • By Xov
    • By Kingfish
    • By Fishing Wiskers
      Top speed is 30mph on flat grass ground.  but it will not go up minor hills forward or reverse without a runing start.  If you start at the bottom of the hill machine will stop about 1/2 way up.  I have the engine cover off and you can see the outside of the drive clutch will stop spining., and the engine does bogg down some.  Dosent matter if engine is cold or warmed up.  Seat belts are connected.  Fuel is clean
      I am not sure how to check for codes with this machine,  can anyone teall me how to do it?
      Compression with hot eng is 145,  valves adjusted to .005 with a cold engine.  Dash shows 426 hours
