Really depends whats most important to you. It sounds like speed and payload are the most important to you. Easiest way to compare is download the spec sheets and compare. That should be a good starting point followed by reviews and availability.
    • By Duane Baker
    • By aefron88
    • By ToughLuck
    • By Paul L
    • By SSgt1994
      Myron
