I installed the 2019 exhaust upgrade yesterday.  Overall went very well, but my rear driveshaft / u_joints are extremely hot.   Is there some sort of heat shield that should be added.  TIA for any input
Tried the wrap. After 8  miles the pipe was red.  Figured it was shortening the head pipe life far too much.  Removed the wrap and prefabed a shield between the headpipe and driveshaft.
  • 7 months later...
I just performed the exhaust retro kit on my 2017, old system was way too restrictive, kept blowing joint gaskets, dealer warrantied the parts, I had to install, did you notice a higher idle? I have no adjustment to bring it down on my unit. Been a stout unit so far, I did wrap my header and exhaust pipes with basalt heat tape wrap, haven't noticed it glowing yet, moving the brake line was fun! (not).
It did not seem to alter my idle speed.  I wrapped mine initially, but turned red quickly.  I removed wrap and  installed a shield to deflect the heat from the u-joints and piped the clutch discharge air toward the exhaust pipe at the expansion pipe.  You might try unplugging your exhaust temp sensor to see if it effects your idle rpm.  I ran mine with it unhooked.  Seemed to not make any difference.  Much better exhaust system.  Good move and good luck.
  • 2 months later...
Well, I took it out on a ride this weekend, 4-5000 rpm pretty steady, mostly gravel roads, about 15 miles in the head pipe blew into 2 pieces, I would say the wrap is a horrible idea, serious metal fatigue, Just thought i'd give an update, now I have to try and find a model number for the 2019 750 so I can see how much a new head pipe and gaskets will be. I'm seriously starting to question buying this machine, seems like everytime I take it out something else breaks! I'll post an update on how I make out with replacement parts
Contact Craig at Motorcycle Doctor in Camdenton Mo. My complete upgrade kit was a tad over $900.  It took about 3 hours.  Well worth h it
On 7/6/2020 at 6:49 PM, Mike DelMedico said:
Well, I took it out on a ride this weekend, 4-5000 rpm pretty steady, mostly gravel roads, about 15 miles in the head pipe blew into 2 pieces, I would say the wrap is a horrible idea, serious metal fatigue, Just thought i'd give an update, now I have to try and find a model number for the 2019 750 so I can see how much a new head pipe and gaskets will be. I'm seriously starting to question buying this machine, seems like everytime I take it out something else breaks! I'll post an update on how I make out with replacement parts.
Put the new 19 set up on mine didnt last 3 months welded it 3 times brakes off at the manifold
Thomas, I agree, The unit itself is sharp looking, but the engineering on this engine setup is definitely lacking, i plan on welding mine, its been sitting since the weekend of the 4th, i may add some structural ribs tot he manifold, it broke right into 2 pieces, and its not a clean break, so i'm not sure what the best course of action is, I think I'm going to have a friend of mine TIG weld it, as he's done snowmobile silencers, and marine lower units for me in the past, He's a master welder, so I probably have a better chance of it holding up if he does it, versus myself doing it with the MIG, (I'm an ok welder, but thats about it).
@VernoI have already installed the upgrade kit, it broke off at the manifold, as Thomas stated, kinda thinking about putting the original setup back on it and modify the muffler to be a little less restrictive, but that involves cutting it open, and re-designing the baffles, etc. Not sure I want to take on that headache right at the moment, (I run an HVAC department, and this has been a brutal summer in NY for AC)...lol
Put strap in front and rear of manifold it is holding up so far any other problems  with motor I've had a lot wish it was good enough to trade in even if it cost 2000 dollars
    • By Greg Kilgore
      Plumbing parts list.
      2 1" x 3/4" x 1" PEX Tee
      1 3/4" PEX ball valve
      1 1" PEX ball valve
      Wide view of the plumbing.
      Kilgore.
    • By tskm
      Tom
    • By amiracle40995
