Head gasket replacement, what’s a top quality head gasket to use? Should a person stud the head? Where would I find a place that sells both? Thank you for any info.
I don’t think oem are that great after looking at what was on water pump. Gasket didn’t even cover the hole surface. Made my own out of gasket material. So that’s why I ask about head gasket. It’s leaking allready with less than 500 hrs. Just as water pump did.
Thank you I will check it out. , where can I get the bolts? I must be lookin in all the wrong places cause I haven’t located any.
    • By Greg Kilgore
      Got a 2021 Axis 500.
      Manual states 38nm.
      Anybody got the answer?
      Have a bed decal that has never been right.  Contacted Coleman Powersports and they have no solution.  Anyone know of a place where I could get a replacement decal or complete decal or graphics kit?
    • By Greg Kilgore
      I did compression test.
      How hard is it to replace?
      Advise?
    • By Jerrys500
      Thanks Jerr
