Hey people! I'm looking for a ring and pinion  set for my rear diff. The bolts that hold the pinion shaft cover in place decided to pull threads and my pinion gear broke some teeth. Any help would be appreciated! I priced out a new diff and it's worth a lot for something that is prone to failure. Thanks in advance
    • By Marie
    • By Steve Waldner
