Only thing I can think of that you haven't already done is look at the fuel pump. There is a filter on it but you have to pull the pump to look at it. If that is the problem consider installing an inline filter before the pump.
Thanks for this. I pulled the pump but cannot find a filter or screen. I didn't want to disassemble it without knowing more. I'll look at installing an inline filter ... good idea.
8 hours ago, Alien10 said:
Just a thought here...how is compression?  Too tight exhaust can burn a seat and leave you with poor compression.
Thanks. I tested compression which is over 100. Since my most recent post I've also looked at the fuel system and wondering if there's something that is affecting fuel flow. I pulled the lines and blew them out but could not find a filter.
Also, I wonder if I made a mistake when adjusting the valves. Intake was tight but exhaust was still good. After doing it, though, I fear I didn't have it at TDC. I couldn't find the marks so spun it around to just after the exhaust opened and closed but before intake opened and closed. TDC is on the compression stroke if I remember correctly (I'm not a mechanic, just a guy who isn't afraid to get his hands dirty) which would be between intake opening but before exhaust, right?
Mine had a small plastic sock kinda thing on the end of a tube. It was all clogged and broken down. Maybe some are different.
    • By GunnersTacklebox
    • By Mike Jenkins
    • By HighSon
