I own a 2024 K9 with 43 hours on it. I haven't had any issues at all except for a loose hose clamp causing an antifreeze leak. Can you advise what type of issues you are having? My only consistent complaint is the loudness of the engine noise inside the cab.
I bought mine March 2024, since then it has had the following:
stuck throttle
leaking windshield
A/C failure
broken CV joint
brakes that won’t compress well enough, won’t hold stop on a slope
emergency brake constantly needing to be adjusted and tightened
roll up windows falling off tracks in the doors
plastic rivets pop loose and fall out
radiator leak
transmission won’t disengage out of gear
transmission bearing replacement
metal shavings in transmission and oil
the dealer tells me I’m not the only one with some or all the same issues.
I own 2022 Kioti K-9 2440 that has had multiple failures from day 1.  It has spent over 3 month in the shop. I will never make that mistake again. I would love to join the class action suit. Where do I sign up. At the moment mine is on the trailer with a separated (broken) CVT primary clutch. 750 hours.
  • Sad 1
    • By GunnersTacklebox
    • By Bbicon
    • By Xov
    • By Dennis
