2016 RZR 900s
Brian Conley
    • By onealmck
    • By jcbigg
      When I try to start my AXIS 500 (from Lowes) there is a buzzing sound coming from the battery compartment and it will not turn over/start. The battery is showing 12.47 volts so that does not appear to be the issue, are there any suggestions on where to look next?
    • By Jason S
      Good afternoon,
      I have a 2022 Bobcat 34XL.  Over time, I have to press harder and harder on the brake pedal before the ignition will fire. Now I have to practically stand on it with all my weight to get it to start.  Does anyone know if there is a spring or something that might need replacing, or have had this issue before? I don't have any schematics of the brake sensor/assembly.
      TIA
    • By Steve B
