Posted (edited)
Edited by KWinTX
added information
The whirring noise is the fuel pump building up pressure. It should stop about 3 to 5 seconds after turning the key to "on" position, (but not to start).
With all other electricals all functioning, it doesn't sound like a battery issue.   No clicking, no reaction to "start" sounds like there is not 12v coming off the key switch to the starter solenoid.
From what you described, I'd be betting that the transmission neutral safety switch being defective or out of adjustment.  Thus not allowing 12v through the key switch to the starter solenoid.
With it in neutral (so you can roll it forward and backward and everyone out of the way) jump 12v to the starter solenoid, it should kick the starter over. Don't let it start the engine, pull a plug wire for safety.
IF that works OK, then suspect the neutral or other safety switch.  If you connect a test light to the starter solenoid's 12v tab that comes from the key switch, you can start wiggling and pulling things on the shifter mechanism to see if you get a quick flash of the test lamp.  Otherwise, get in there with a voltage/continuity tester to see where your 12v is failing to reach the starter solenoid.
My 2021 Hisun (Coleman branded) 550 has no brake safety but yours might, its a later model .  I do know that if the shifter is even slightly out of the "N" position or if the "N" light on the dash isn't on, you will get nothing when turning the key to start, but everything else electrical will work.  Sounding familiar?
Good luck, let us know how you are coming along.
    • By SkyPilot56
    • By KnS
      Hey Team, our issue is not as bad as some I've read here...  We put some songs one a 64GB USB stick, plugged it in and the USB icon is still greyed out and won't let you select.  Any suggestions?  All the songs are in the root directory.  Thanks, Kevin & Shelbie
    • By Pick a name
    • By Xov
