Shotgun Mounts
By Kingfish
By Ridge Runner
thanks
Ridgerunner
By REDfletching
Spent today at a Honda dealership looking at their 520 side by side, then on the way home past our Lowes noticed they had several new UTVs on site, so we U-turned and ducked in there. We were impressed that all that came for $9,999 metal whole length skid plate, nice sized bed, roof, windshield, side mirrors, winch, upgrade looking tires… all of which would have added thousands of dollars to an already expensive Honda 520. Now Honda does have a great reputation from my trusted UTV experienced buddy, so it has that going for it.
