I found another forum that had someone with a similar problem and found this reply,
"there is no way to disconnect the limiter,
The engine is designed to rev as high as it can without causing damage, if you were to make it rev higher, the valves would float and come into contact with the piston,"
    • By CapnWalleye
    • By Marie
    • By Marie
    • By A P
