Hi Everyone, This is my first post.  I believe I have my starting issues narrowed down to decompression springs (good grounds, one way bearing, etc.) so I order them and now I have no idea how to install.  I am handy enough, but looking for a video or other instructions on how to replace them.  If this has been covered and I just can't find it, appreciate some input on where to go.  If not, would appreciate some instruction!  Haven't done this one before.  Thanks.
I am not too familiar with your type machine, but if im thinking right they would go on the camshaft.
Here's another thread about this issue, Thread   <--- Click.
 But i do have to ask, have you checked your valve lash/clearance?
I assume the engine is slow to initially turn over. We found the cause to be incorrect cam setting not opening valve when it should. Take the rocker and side cover off and you can see how and when it should work. Fixed it by adjusting. You won't find anything relevant  in the service manual.
    • By GunnersTacklebox
    • By staind
      thanks Dan D. aka staind
      Picked up an essentially new 2022 UT400 with 9 miles on it.  Decided to change the oil because it's probably never been done.  Pulled the dipstick and noticed it was overfull then went and pulled the drain plug and took off the filter and it was like brown water running out.  What should I start checking?
    • By Bjabbarw
    • By rev6engines
      Black Friday is here, and we’re excited to give our offroad family 20% off on all parts and kits! Whether you're prepping for new trails or just fine-tuning your rig, we've got what you need to keep rolling. Now Is also a great time to upgrade your sled, winter's coming fast!
      If you have any questions or need help finding the right part, feel free to call, text, or email us. We’re here for you!
      Call or Text:
      801) 489-8697
      Email at:
      [email protected]
      Happy riding!!! 🤘
