Maxxis Endurocross
By great8redsfan
Okay folks. I have a low power issue. Been like this for a few years. Place I work at bought 3 and all have lost most of the pulling power. They gave them away after local shop worked on one for 3 months and it had great power for about 1 month and then crap. They replaced throttle body, fuel injector, spark plug and IAC motor. Seat belt switches have wires cut and left open so no seat belt warning light anymore. It revs to 6k rpm in neutral but when put in gear and take off in low it just doesn’t seem to want to go anymore. Running 93 octane fuel with Stabil. Any ideas greatly appreciated. I dont have a scan tool but no codes on dash. If held to floor it pops a little and runs almost 5K rpm but if I let off pedal about an inch it smoothed out and revs up to 6k rpm.
By Xov
By johnpeter
RZR 1000 XP EPS - Rocks & Trails Edition 2020 On Ebay
https://www.ebay.com/itm/355474995514?
By sxsadventurerally
It’s time for the 10th Annual SXS Adventure Rally on the Rocks. Join us in the best sandbox this side of your childhood playground! Experience the thrill of exploration, the excitement of speed, the sensation of Mother Nature and machines.
Come to gorgeous Southern Utah as the best industry Side by Sides and UTV's hit the sand, dunes, rocks and endless vistas of Sand Hollow State Park for the adventure of a lifetime. May is perfect riding weather and is sure to bring a smile to everyone’s face.
This SXS/UTV family friendly event will overload the senses with professionally guided trail rides, rock crawling, camping, factory demo rides, rock crawling competitions, scenic rides, education classes, cornhole tournament, music concerts and more.
Official expert guided trail rides are just $50 per person per day. Vendor areas, demo rides and entertainment fun open to the public with state park entry.
YOU DO NOT HAVE TO ENTER THE EVENT TO COME ENJOY THE VENDORS AND DO TEST/DEMO DRIVES WITH INDUSTRY MANUFACTURERS.
For more information and full 2024 event schedule and fees. Have questions? Hit the FAQ page: https://SXSAdventureRally.com/faq
~ PURSUE YOUR SXS/UTV PASSION ~
REGISTRATION: https://SXSAdventureRally.com/registration
Sponsored by:
GBCTires.com – Presenting Sponsor
Sponsorship and Vendor opportunities available. Please contact us for more information and bring your business to the true grass roots of the sport!
Instagram: https://www.instagram.com/SXSAdventureRallyOnTheRocks or @SXSAdventureRallyOnTheRocks
Facebook: https://www.facebook.com/SXSAdventureRallyOnTheRocks
For Additional Information, contact [email protected] or (435) 703-4444
By res2fr
I have an issue and I'm hoping that someone can help with a little Wisdom. I have a 2016 Massimo MSU500 UTV that blew a time chain while out riding. It has been torn down to replave the chain and Sprocket amount other things that will be renewed. The problem comes in with setting Top Dead Center on the motor. The Manuals all teel one to line up hash marks on the flywheel with a point on the side cover under what's referred to in several place as a manhole cover. Its a large headed cap/bolt that unscrews and allows you to view the edge of the flywheel. There are hash marks on the flywheel that your supposed to turn the crank until you get the proper alignment between a certain hash mark and a reference point on the Case. Problem is there is NO reference point on the case there. I also have another 2016 MSU500 and a 2014 Coleman 500. Not one of these machines have a reference mark of any kind in that location. (I have pictures if needed)
I know I can use the old pull the valve covers and rotate the crank and rely on getting the right point where Both Intake and Exhaust valves are closed at hopefully the correct point in the piston stroke. Is there any other reference point that could be used for this or is this the only thing left to use for finding TDC? Gotta Love documentation that doesn't match the equipment it's supposed to be for, any help would be greatly appreciated. Even if just to tell me that's about my only option.
Thanks to all who even take the time to read my rambling question.
Robert
