I have an exhaust leak and need to remove the dump bed. There are 2 pins, thats easy but my issue are the 2 struts. They don't have the clip to help snap them on so I was wondering if a large screwdriver and some force help take them off? I add some force to try to take off the struts but got nervous that I was going to break or bend them. Thanks
    • By Mmcleary
    • By Pick a name
    • By Marie
