Polaris RZR Ranger 800 Engine Rebuild Service S crew 4 Xp Motor 700
By Quentin Walker
Hi all. I am in dire need of some help. Through our university, we are competing in the Baja SAE competition. It is a collegiate engineering design competition to design and manufacture an off road dune buddy.
To cut to the chase, we were donated a 2011 Hisun HS 700 UTV, and we are using suspension and drivetrain parts off of it in our design. I am in the process of ordering new parts, but I am coming to a standstill.
Does anyone have any experience ordering parts for these machine?
From what I have found online, these machine were sold by Tractor Supply, along with a few different brands that share the same parts (Supermach, Coleman, Massimo, etc.)
Any help is appreciated. Thanks in advance.
By Jon V
By MISTERTIRE66
Recently inherited 08 joyner renegade r4 800.. seems to be sound mechanically but I cannot find bal joints. Any pone help with other replacement part number please.
By LarryLarryQuiteRepairy
Hello,
Background: Bought a used 2012 700, added 2 small LED lights, wiring for a sprayer and changed front CV axles.
Had no electrical issues until recently. The old battery stopped charging so we got a new one, Rhino still wouldn't charge it.
-Started next day, drove 15-20min, then out of nowhere the check engine light came on and temp too. 4WD started to automatically engage and disengage repeatedly. Charging display started jumping all around between 11 to 13 to 15v.
-Relays, fuses, and battery connections seemed good.
-Continuity on rectifier would jump btwn OL and 00.0
-Rectifier wires from stator all read 20-21v at idle
-Rectifier diode test had 1 bad reading. So, I replaced it with a new one (but still using original plugs)
Started it up, still shows no change (12.1v idle, 12.8 with some RPM)
Also, I feel like now I maybe also smell burning plastic?
Does anyone have experience with this problem or have a recommendation of where to go next?
