TIRES
By CYJSP2009
Dear Joyner owners
3. Cables,
4. Brake parts
5. Engine parts
6. Other parts.
Have a good weekend
Casey / Leaf Asia
2023-11-17
By joynersfuntillitbreaks
so i just picked up a 2008 1100 trooper and iv ordered a few parts for it now and 99% of what i got fits perfect my issue now is my rear wheel hub is stripped out got a new cv and it fits great but i order 2 different hubs from 2 different places now and they are both wrong the spline opening is to small to fit the factory cv shaft and yes the shaft factory part #s are the same paid 250 for an original new replacement if anyone has anything that works to replace the original hub please point me in the right direction
By hetovi
Hello everyone.
I recently bought a Can-Am Ryker and I'm looking to customize it with some accessories. I’ve seen a lot of options out there but wanted to get some recommendations from fellow riders.
What are the must-have accessories for comfort, style, or performance?
Specifically, I'm considering a windshield and better footpegs—are these worth the investment?
Also, any thoughts on storage solutions like saddlebags or rear cases?
Would love to hear your personal experiences with any mods you’ve done.
By Woody77
UTV MASSIMOREPLACED STATOR WANT start replaced rectifier still want start stator ohms out 5 ohms each leg what could be wrong at this point
By Jon V
Good afternoon. When the timing chain came off its lower gear (previous owner had over-tightened the tensioner), I ordered new parts.. chain, oil-pump chain, tensioner etc.. But now that it's time to put it back together, the main crankshaft makes a clang noise and stops when you turn it by hand. I want to solve this before assembling everything. The camshaft cover is off so that the valves aren't being activated. Should the transmission be in neutral to turn the crankshaft? The engine was running fine until the chain came off the lower gear. Then it would spin when the starter motor engaged so I assumed the crankshaft was spinning. Any advice is appreciated.
