Ok trying again... I have 2018 cub cadet 750. Having clutch issues. Has anyone bought a upgrade for them and where did you get them and about how much. Thanks for any help given. From what i have looked over on here. Lots of nice helpful people
The clutches themselves. There is like 3 of them I guess. Wet clutch primary secondary from what I hear. My problem is taking off and can't get my speed anymore once it does grab good.
  • 2 months later...
I just put in a EPI clutch upgrade. My starting system is messed up so I can’t review it for you yet.
Putting it in was not too bad. Buy the tool for the secondary clutch though. No way to do it safe otherwise.
  • 5 months later...
How did u make out with your clutch
  • 11 months later...
Misfiring after shifting from low to high.
After shifting gears the cub 750 challenger starts to misfire and barely will run. Any suggestions. It idles great and runs good until it shifts. 2018 year.
    • By Gerald Mohs
    • By Wolfpaak
      Kenny
    • By GunnersTacklebox
