I have a 2016 cub cadet challenger 750. In the past month it has started to lose power at about 25 mph, sounds like it is struggling for fuel. Any suggestions?
  • 1 year later...
If the driver seatbelt is not clicked in it will cut power at around that speed as a safety feature to ensure you wear your seatbelt. I just click mine in behind my back.  Not sure if that feature is on the carbureted model. If it is there have been reports of the seatbelt module going bad.
  • 1 year later...
I also have a 2016 cub cadet challenger 750 eps crew that is having the same issue. It is fuel injection, new injector, plug, and have all the saetbelts buckled, still is having the problem. Any suggestions
    • By Jim Kessell
      2005 American Landmaster
      EH65 Subaru Robins
    • By hisun junk
    • By JSwearer
    • By Jacob E freeman
    • By A P
