YAMAHA AWARDS GRANT OF $15,000 TO THE OFF-ROAD BUSINESS ASSOCIATION
By Matthew Smith
2013 Bennche Bighorn 700 EFI
By rdborra
By CYJSP2009
Dear Friends,
Buy 1 piece: Get 5% discount,
Good Luck
Casey / Leaf Asia
July-07-2022
Coleman UT 400 has a strong sulfur/emissions smell from exhaust all the time. Kind of like it’s running rich and a catalytic converter is trying to make it run cleaner so it smells bad. Also misfires when warm. Idles fine. Full throttle fine. In between it cuts out. Do these have catalytic converters? Almost acts like it might be clogged if so.
