I bought a used RTV 900 and was told it is a 2012. I thought I would verify that. I can't find anywhere I can look this up.
KRTV900A61057114 is the product identification number.
Thanks for any help.
Let's presume the first character is missing from the VIN.  If so, then the year model charactert 6 would become the 10th character and indicate that it is a 2006 or 2036 model year (not realistic).
If we presume the last character is missing from the VIN, then the 1 to the right of the 6 would become the 10th character and indicate that it would be a 2001 or 2031 model year (not realistic).
The letter O or the number 0 is never used to indicate the model year.
So, lacking any further info, the letter A is the closest to any realistic model year character and that indicates that it might be a 2010 model year.
(770) 532-0038 is their phone number in GA.  I don't know if it is still active/current.  But it would be worth a call to see if they can help.
  • 1 year later...
  • 1 year later...
  • 2 months later...
  • 4 weeks later...
    • By Marie
    • By Grant
