Who sells hisun parts besides the picture I have up. They have what i need if I decide to order them. It will be two weeks wedsday that royal king has had my utv and parts aren't ordered yet. It's under warranty and parts will be free but I hate waiting, and I know if I take it back and do it my self the warranty will be over. But looking for another web site I can look up parts besides this one.
I got my hisun 550 back, royal king had it for a month. Replaced drive shaft sleeve and rear drive shaft connecting seat. Which mine had a spring behind the nut and washer that screwed to the pinion gear.  I called hisun and asked them about that compression spring in there and they told the mechanic to put it back in.  So I got it home and called the motorcycle doctor and he told me there was not supposed to be a spring in there. The mechanic at Royal King told me he put it back in, so I took it all apart and the spring was not in there after he told me he put it in. Could of saved me 4 hours taken it apart and putting it back together. I wouldn't let royal king work on my utv ever again even tho it's still under warranty. Here's pictures how it was put together. At least I know now my bolts are all tight.
    • By Ductking1
    • By hisun junk
    • By Justine
    • By A P
